larssimony
Oracle and JMP 12
Hi
I have created a JSL i JMP 11.1.1 which connects to my Oracle database and runs fine with following code:
Clear Globals();
databaseConfig = "DRIVER={Oracle in OraClient11g_home1};DBQ=MyServicenameFromOra;UID=MyLogin;SPWD=MyPassword;";
sql =
select *
from MyTable
MyData = Open Database( databaseConfig, sql, "My Data" );
Why can't I use same code in JMP 12.1.0?
Iget following error message in log:
[Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
If I go back to JMP 11.1.1 it works fine again. I have both versions of JMP installed.
I have Oracle driver installed with a TNSNAMES.ORA file.
Lars
pmroz
Re: Oracle and JMP 12
Hi Lars,
I can connect to Oracle using JMP 11.2.1 and 12.1.0 with no problem.  Are the two versions the same "bit-ness"?  I.e. 64-bit JMP needs 64-bit Oracle, and 32-bit JMP needs 32-bit Oracle.
Not sure if it's a typo, but my connection string has PWD, not SPWD.
Regards,
Peter
pmroz
Hi Lars,
Regards,
Peter
larssimony
Hi Peter
Sorry, it was a typo when I removed my password ect.
I will try installing a 64 bit Oracle driver to my 64 bit JMP.
Regards,
Lars
larssimony
Just noticed my JMP 11 is 32 bit and 12 is 64 bit.
Thanks for your help.
Lars
