bzanos
JSL to plot graph with last N values of a column
I am writing script to plot graph with last 10 values of a column. Below is the script I use which I learned from previous post.
It works. But I notice the this wording " Where( Row() > (n - last n) ) " appear in the graph which I do not want it to show.
Is there a way to remove this wording? or Is there other way to write JSL script to plot graph with last N values of a column?
last n = 10;
n = N Row( dt );
biv = dt << Bivariate(
	Y( :weight ),
	X( :height ),
Re: JSL to plot graph with last N values of a column
Here is a quick example.  It was just recently covered in a Discussion Here
last n = 10;
n = N Row( dt );
	Y( :weight ),
	X( :height ),
(report(biv)<<topparent)[textbox(1)]<<delete;
last n = 10;
n = N Row( dt );
	Y( :weight ),
	X( :height ),
bzanos
works great. Thanks
