shasha_2
JSL scripting query regarding jmp table call
I want to call a table which I am using in the current JSL script into another script, is there any way in which I can do that? I have attached snippet of the code, I want to use the dt1_Name (or dt) in another jsl script which I have linked to this script:
dt1_Name= Pick File(
	"Select the JMP MasterFile",
	{"JMP Files|jmp;jsl;jrn", "All Files|*"},
	1,
	0,
Show( dt1_Name );
dt = Open( dt1_Name );
Show( dt );
bwidth = 150;
dt << bring window to front;
box_win = New Window( "Select Columns",
	H List Box(
		Panel Box( "Select Columns", ColListData = Col List Box( dt, All, Grouped,width( bwidth ), nLines( 5 ) ) ),
		V List Box(
			Panel Box( "Case Selected Columns Into Roles",
				Lineup Box( N Col( 2 ), Spacing( 3 ),
					Button Box( "START DATE", colLista << Append( ColListData << Get Selected ) ),
					ColLista = Col List Box( width( bwidth ), N Lines( 1 ), Max Items( 1 ), Min Items( 1 ) ),
					Button Box( "END DATE", colListb << Append( ColListData << Get Selected ) ),
					ColListb = Col List Box( width( bwidth ), N Lines( 1 ), Max Items( 1 ), Min Items( 1 ) ),
					Button Box( "PAY DATE", colListc << Append( ColListData << Get Selected ) ),
					ColListc = Col List Box( width( bwidth ), N Lines( 1 ), Max Items( 1 ), Min Items( 1 )),
					Button Box( "STATUS", colListd << Append( ColListData << Get Selected ) ),
					ColListd = Col List Box( width( bwidth ), N Lines( 1 ), Max Items( 1 ), Min Items( 1 ) ),
					Button Box( "Remove",
						ColLista << RemoveSelected;
						ColListb << RemoveSelected;
						ColListc << RemoveSelected;
					Spacer Box()
			Lineup Box( N Col( 3 ), Spacing( 0, 3 ),
				Spacer Box( <<Set Auto Stretching( 1, 0 ) ),
				Button Box( "OK",
					acol = ColLista << Get Items;
					As Column( acol ) << Set Name( "STARTDATE" );
					bcol = ColListb << Get Items;
					As Column( bcol ) << set name( "ENDDATE" );
					ccol = ColListc << Get Items;
					As Column( ccol ) << set name( "PAY DATE" );
					dcol = ColListd << Get Items;
					As Column( dcol ) << set name( "STATUS" );
					box_win << Close Window;
					Close( dt, Save );
					Include("$Desktop/nextstep.jsl");
				Button Box( "Cancel", box_win << Close Window )
pauldeen
Re: JSL scripting query regarding jmp table call
If your first script looks like this:
Names default to here(1);
a = 1;
::b = 2;
From a second script, notice you can look at the b variable because it has been globally scoped with the :: operator in front of it.
try(show(a));
try(show(::b));
So as long as you define your table variable as globally scoped, you should be able to call it from other scripts.
6 REPLIES 6
Depending how you have built your script(s), using Namespaces might work.
If you start off each script with
Names Default to Here( 1 );
All of the variables etc. in that specific script will be unique to that script, and only that script.
shasha_2
Thank you
shasha_2
Thank you!
pauldeen
a = 1;
::b = 2;
try(show(a));
try(show(::b));
shasha_2
Thank you, it's working!
