LogitTurtle576
Changing column format only for numeric ones via JSL
I can't figure out how to change the format for all numeric columns in my table to be with just 2 dec. via JSL.
The following code is sending errors because it tries to do it for non numeric columns too.
For( i = 2, i <= N Col( dt ), i++,
    Column( dt, i ) << Format( "Fixed Dec", 12, 2 )
Thanks in advance for any help.
Re: Changing column format only for numeric ones via JSL
Check Data type first with
<< Get Data Type
and compare it in If-statement
<< Get Data Type
David_Burnham
FYI, you can also get a list of only numeric columns
lst = dt << get column names(numeric);
-Dave
