chungman89
JSL script on graph builder box plot all column against wafer number
Hello, I am trying to plot my data (multiple parameters) against the wafer number. I have found a script from the community for the distribution graph. Therefore, I have modified it by replacing Distribution function with Graph Builder function. However, only one graph was shown at the report instead of all the graphs. Can I have you advice on this script? Thank you.
dt = Current Data Table ();
// Get all of the continuous data columns
colNames = dt << get column names( string, continuous );
// Create the JSL to create the script
theExpr = "Graph Builder(
	Size( 1414, 795 ),
	Show Control Panel( 0 ),
	Variables( X( :WF_NUM ), Y( colNames[1] ), Color( :WF_NUM ) ),
	Elements( Box Plot( X, Y, Legend( 7 ) ) )
For( i = 1, i <= N Items( colNames ), i++,
	theExpr = theExpr || ", Graph Builder(
	Size( 1414, 795 ),
	Variables( X( :WF_NUM ), Y(colNames[" || Char( i ) || "] ), Color( :WF_NUM ) ),
// place the closing ")" to complete the command string
theExpr = theExpr || ");";
// Run the created JSL
Eval(Parse(theExpr));
Thank you for your help.
Dominic
Re: JSL script on graph builder box plot all column against wafer number
The JSL you provided can be simplified  to produce the charts you want.  Below is a modification of your code
dt = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
// Change the name of the Wafer column to match the name used
// in the Graph Builder code
dt:wafer << set name( "WF_NUM" );
colNames = dt << get column names( string, continuous ); // Since there are 128 columns that could be plotted, the code has been // modified to just produce 3 of the plots. The commented out code // should replace the "i <= 3, i++," to plot all graphs For( i = 1, i <= 3, i++, // N Items( colNames ), i++, dt << Graph Builder( Size( 1414, 795 ), Show Control Panel( 0 ), Variables( X( :WF_NUM ), Y( As Column( dt, colNames[i] ) ), Color( :WF_NUM ) ), Elements( Box Plot( X, Y, Legend( 7 ) ) ) ) );
chungman89
Hello @txnelson ,
Thank you for your reply.
The graphs were plotted with your modified code. One extra question regarding the modified codes. When I was using the reference code from the community for distribution graphs, all the graphs were summarised into a single report which make it easy to export to powerpoint. May I ask what extra lines are needed for the code you have simplified to summarised graphs into a single report?
Dominic
All that needs to be done is to place the graph generations inside a New Window() function.
nw = New Window( "Graphs",
			Size( 1414, 795 ),
			Variables(
				X( :WF_NUM ),
				Color( :WF_NUM )
chungman89
Thank you for your help @txnelson
Appreciate the answer with details and code.
