SCWong
JSL - opening files in the same folder
Hi all,
I have 3 files in a folder that i'm working with.
A = master datatable
B = Source 1
C = Source 2
I'm trying to write a script that can update information from B and C into A. How do I call up the datatables B and C without typing in the entire path of the file? Reason being there might be other people who will download this entire folder to use so I want the file path to be flexible.
Thanks.
Re: JSL - opening files in the same folder
Depends a little how you are opening the A file. Below is one idea how you could approach this:
dt_A = Open("$SAMPLE_DATA/Boston Housing.jmp");
a_path = Convert File Path(dt_A << get path);
folder_path = Substr(firstTable, 1, Contains(firstTable, "/", -1));
b_path = folder_path || "B.jmp";
c_path = folder_path || "C.jmp";
