terapin
JSL instruction to call script saved with data table?
I'm trying to call a script saved with a data table from another JSL script.  Is that possible?  I've used Include() before to call a JSL file, but can't figure out how to call a script that is saved with a data table.
Re: JSL instruction to call script saved with data table?
Yes, this is possible--for example:
eval(dt << get table property("Distribution"));
The above line runs a script called Distribution that has been saved to the data table referenced by dt.
Cheers,
Brady
Cheers,
Brady
terapin
Fabulous,
Thought there would be some way to do it.  Thanks for letting me know.
uday_guntupalli
Level VIII
Is there a way to get a reference and then extract the values from the analysis platform ?
@Craige_Hales @brady_brady @pmroz ?
Best
Uday
ian_jmp
Level X
NamesDefaultToHere(1);
dt = Open("$SAMPLE_DATA/Big Class.JMP");
// Find out what scripts are stored
sl = dt << getTableScriptNames;
// Pick a script at random
s = sl[RandomInteger(1, NItems(sl))];
// Run it
s = dt << runScript(s);
// Get a reference to the analysis object
obj = Report(s) << getScriptableObject;
// Find out what messages this object understands
ShowProperties(obj);
Eric_Hill
Hey,
There is a simpler way to do this that may have been added after @brady_brady posted his solution. You can just do:
dt << Run Script("Distribution");
Eric
