Neo
Neo
JSL function with SQL Join pulling data rows 3 times compared to one without JOIN -why?
The first function below with SQL INNER JOIN pulls each data rows (for LNo) two additional times from the database compared to the second function below without JOIN. Where am I going wrong?
opnDtb = Function( {R, M, T}, {dtm},
	dtm = Open Database(
	"Driver=SQL Server;
	Server=ABCD-EFGH;
	DATABASE=myDB;
    Trusted_Connection=Yes;",
		"SELECT SM.[LNo], SM.[TestDate] AS [orgTestDate], SM.[Median], MT.[EntryDate] AS [TestDate]
	     FROM [myDB].[dbo].[P_STD_" || R|| "_" || T || "_" || M || "_SUMMARY] AS SM
	     INNER JOIN [myDB].[dbo].[P_STD_" || R || "_" || T || "_" || M || "_META] AS MT
	     ON SM.LNo =  MT.LNo"
	Return( dtm );
////TEST
clear log (); R  =  "D12"; T = "7"; M = "5"; dtm = opnDtb(R, M, T); dtm << set name ("sTable");
	"Driver=SQL Server;
	Server=ABCD-EFGH;
	DATABASE=myDB;
		"SELECT SM.[LNo], SM.[TestDate], SM.[Median] FROM [myDB].[dbo].[P_STD_" || R|| "_" || T || "_" || M || "_SUMMARY] AS SM"
	Return( dtm );
////TEST
When it's too good to be true, it's neither
Re: JSL function with SQL Join pulling data rows 3 times compared to one without JOIN -why?
Have you checked what type of data you have in MT table (maybe there are multiple rows for each LNo in that table)?
