MFVIT
JSL for converting a formula to its results
I have the following jsl code
dt << New Column( "I (%)", (:Mean * 100) );
that takes a column (Mean), multiplies by 100 and create a new column called I(%) with the formula.
I do not want the formula but just the result of the calculation in the new column. How can I do this?
Many thanks.
13 REPLIES 13
MFVIT
Re: JSL for converting a formula to its results
Thank you very much, very useful.
MFVIT
Many thanks.
You do not need a formula at all. I recommend not using column formulas when scripting unless you want the values to dynamically change after the script is done. So your case could be solved this way:
dt << New Column( "I (%)", Numeric, Continuous, Values( (:Mean << Get Values) * 100) );
Craige_Hales
Cool!
Craige
