    Regular business hours will resume at 9:00 a.m. ET on Friday, Jan. 2, 2026.
MFVIT
JSL for converting a formula to its results
I have the following jsl code
dt << New Column( "I (%)", (:Mean * 100) );
that takes a column (Mean), multiplies by 100 and create a new column called I(%) with the formula.
I do not want the formula but just the result of the calculation in the new column. How can I do this?
Many thanks.
13 REPLIES 13
ian_jmp
Level X
Re: JSL for converting a formula to its results
NamesDefaultToHere(1);
// Sample table
// Add a formula column
dt << NewColumn("BMI", Numeric, Continuous, Formula(:weight/(:height^2)));
// Make sure the formula is run
dt << runFormulas;
// Wait a little, then remove the formula
Wait(3);
Column(dt, "BMI") << deleteFormula;
Craige_Hales
The wait(3) is just so you can watch it; it is not required after <<RunFormulas.
You can also use the formula editor to clear the formula for the same effect.
Craige
MFVIT
Thanks! Very clear.
Try using <<Set Each Value() instead of Formula()
That message is not helpful in this case. It is used to set every row in the target column to the same constant value.
Hee is a simple example using Set Each Value
names default to here(1);
dt=open("$SAMPLE_DATA\big class.jmp");
dt << new column("times100", numeric, continuous, set each value(:height*100));
Craige_Hales
Cooler! I'd assumed each value had to be set to the same value.
Craige
That behavior is the intended purpose of the << Set Each Value message as it is documented.
This maybe gets a bit out of topic and I can create different post to discuss this further...
Even though the documentation is what it is for Set Each Value (JMP documentation isn't always exactly on point...) I feel like it is the easiest way the way to handle cases like this. You can easily use complicated "formulas" with Set Each Value without worrying about removing the formulas later. With Values() the calculations might get a bit more difficult to do, see my example (I'm definitely not proficient with JSL Matrices so there is most likely way easier way to do what I did in my example).
Example with Formulas, Set Each Value and Values:
//With formulas
newCol = dt << New Column("Formula_simple", Numeric, Continuous, Formula(:height*:weight));
newCol << Delete Formula;
newCol = dt << New Column("Formula_ColMin", Numeric, Continuous, Formula(:height*ColMin(:weight, :sex)));
//With Set Each Value
newCol = dt << New Column("SetEach_simple", Numeric, Continuous, Set Each Value(:height*:weight));
newCol = dt << New Column("SetEach_ColMin", Numeric, Continuous, Set Each Value(:height * ColMin(:weight, :sex)));
//With Values
newCol = dt << New Column("Values_simple", Numeric, Continuous, Values((:height << get values) :* (:weight<< get values)));
newCol = dt << New Column("Values_ColMin", Numeric, Continuous, Values(
	Summarize(exg = By(:sex), exm = Min(:weight)); //get min values by group
	m_val = J(N Rows(dt),1,1);//matrix for values
	height_vec = :height << get values;
	For(i = 1, i <= N Items(exg), i++, //loop to "fill" matrix for values
		tempRows = Loc(:sex << get as matrix, exg[i]);
		m_val[tempRows] = height_vec[tempRows] * exm[i];
	m_val;
What does Set Each Value do behind the scenes because it seems to work just fine? Should the documentation maybe be updated to include this behavior or new function created to do this? It could break quite many scripts people have if Set Each Values behavior were to be changed.
