SDF1
JSL code & Summarize help
Hi JMP community,
  JMP Pro v17.
  I  have a script that had been working last month, but doesn't appear to be working anymore. I have a data table where one column is named :Date (see attached data table). The following script is supposed to summarize the data table by the Year( ) of :Date and generate a list of years for the variable "yrs".
Summarize( dt, yrs = By( Year( :Date ) ) );
  For example, it is supposed to return a list of dates like {"2022", "2023", "2024"} and so on, because the Year( ) command is supposed to extract out just the year value from the :Date column, however it doesn't.
  If you remove the Year( ) command around :Date and run it like this:
Summarize( dt, yrs = By( :Date ) );
  The result is a list of all the individual dates, here's an excerpt:
{"09/29/0263", "01/30/1930", "02/11/1955", "05/03/2002", "08/13/2002", "10/19/2002",
"01/01/2021", "01/02/2021", "01/06/2021", "01/18/2021", "01/30/2021", "02/12/2021",
"02/13/2021", "02/15/2021", "03/26/2021", "03/27/2021", "03/28/2021", "03/30/2021",
"04/23/2021", "04/24/2021", "04/25/2021",}
  There are some mistyped dates, but this can be ignored right now.
  I don't actually want all the individual dates, I just want a list of all the years. Unfortunately, when I try to execute yr = Year( :Date), then I get a null/empty variable for yr. This ends up not being able to be evaluated by the next By( ) command around it in the original JSL. I don't know if I need
  What I find strange is that about a month ago when I was building this code, it seemed to work just fine, but now it's not functioning like it was.
  I'm sure I'm missing something simple that's causing this problem, but I can't figure out what it is. Or, I'm thinking about the Summarize( ) and/or how it uses the By( ) group in it.
Thanks for any thoughts/feedback!,
DS
10 REPLIES 10
Re: JSL code & Summarize help
I don't think you can do that with Summarize but you could use Summary with transform column if you don't want to create new column to your table
dt = Open("$DOWNLOADS/Date.jmp");
dt_summary = dt << Summary(
	Group(Transform Column("Year", Formula(Year(:Date)))),
	Freq("None"),
	Weight("None"),
	Link to original data table(0),
	output table name("Summary of Date grouped by Year"),
	Private
years = dt_summary[0, 1];
Close(dt_summary, no save);
Show(years);
