See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
JSL Tutorial
felix_doktorman
Hello. Is anyone can provide link or pdf to JMP 11 JSL Tutorial? I am beginner in JSL scripting, so this might help.
Re: JSL Tutorial
Our support site is indexed pretty well by google; if I search for jsl for loop example I find Iterate at the top of the list.  You'll probably land on a JMP 12 page rather than JMP 11, but most JSL does not change between JMP versions.
Here's the beginning of the support site.
If you get stuck, this is a great place to ask questions.
ron_horne
Re: JSL Tutorial
hi felix.doktorman
welcome to the club.
if you want to start scripting with JMP i suggest you go to a book called "Jump into JMP scripting".
this is the reference:
https://books.google.co.uk/books/about/Jump_Into_JMP_Scripting.html?id=Wd6p3YrbDi8C&source=kp_cover&...
this is the best introductory so far. once you are done with this book try "JSL companion"
https://books.google.co.uk/books?id=42Bt1lDZLYoC&printsec=frontcover&dq=jsl+companion&hl=en&sa=X&ved...
Best,
ron
Byron_JMP
Re: JSL Tutorial
I absolutely agree with Ron and Craig above. Another good resource that is easy to get at is the Scripting Guide. From the Help Menu, click Books, then Select the scripting guide.  The other really helpful resource is the Scripting Index which is also under the Help menu tab.
This Mastering JMP topic is pretty good too (I might be biased) except that I hear the presenter goes a little fast.
Automating Analysis and Reporting Using JMP Scripts | JMP
