Hello All,
I would like to write a JSL script to automate a TOST (Two-One Side T-Test) on a large number of metrics (500+).
The TOST works by pair of “levels”, so working with 2x levels is easy, because it requires only 1x row per “pair”.
I already wrote a script that works well for 2x levels by generating a “Combined data table” and adding more columns with formula to it, which end up with the results: “Equivalent” or “Not Equivalent”.
The problem thickens when I want to work with more than 2x Levels, it would require to find all possible unique pairs of “Levels” and then run the TOST math for every combination of Metric + pairs of Levels.
I found a way (on this forum) to find all possible unique pairs from a list and put them in a table or in a nested list (NchooseKmatrix()).
But I am stuck there. What I need is:
1- to populate a new table with all possible combinations of Metrics (Column1) and all pairs of possible levels (Column2 and Column3).
2- Then add the stats for each pair of level on each row
From this point I will be able to figure out the math to finalize the TOST.
I have attached a script that generates a dummy table, then a combined data table from the Oneway analysis, then my unsuccessful attempt of creating a third table with all combinations of Metrics + Unique pairs of level
Thanks in advance for your help
clear symbols();
Deletesymbols();
//Create table with random distribution (table 1)
dt = New Table( "tabletest",
Add Rows( 500 ),
New Column( "Product", Character, "Nominal", formula("Product " ||char( Random Integer( 1, 4 )))),
New Column( "Metric1", Numeric, "Continuous", formula( Random Normal( 10, 1 ) ) ),
New Column( "Metric2", Numeric, "Continuous", formula( Random Gamma( 10, 1 ) ) ),
New Column( "Metric3", Numeric, "Continuous", formula( Random Gamma( 10, 2 ) ) )
Column( dt, "Metric1" ) << set property( "spec limits", {LSL( 5 ), USL( 25 ), Show Limits( 0 )} );
Column( dt, "Metric2" ) << set property( "spec limits", {LSL( 0 ), USL( 40 ), Show Limits( 0 )} );
Column( dt, "Metric3" ) << set property( "spec limits", {LSL( 5 ), USL( 40 ), Show Limits( 0 )} );
dt << save( "$Desktop\tabletest.jmp" );
//Get a list from all unique Product
SplitBy = "Product";
summarize(ColumnSplitBy=by(Column (SplitBy)));
show(ColumnSplitBy);
For( i = N Items( ColumnSplitBy ), i > 0, i--,
If( ColumnSplitBy[i] == "",
Remove From( ColumnSplitBy, i, 1 );
//Get Column name
MetricCols = dt << Get Column Names( numeric, continuous, "string" );
//Get all unique combo of 2 Products
ColumnSplitByCombo = aslist( nchoosekMatrix(nitems(ColumnSplitBy), 2));
show (ColumnSplitByCombo);
//Create a combinaed datatable with stats (Table 2)
ow = dt << Oneway(
Y(Eval(MetricCols)),
X(Eval(SplitBy)),
Means and Std Dev(1),
Dispatch(
{"Means and Std Deviations"},
"Std Dev Lower 95%",
NumberColBox,
{Visibility("Visible")}
Dispatch(
"Std Dev Upper 95%",
NumberColBox,
Invisible
tb = Report(ow[1])[Outline Box("Means and Std Deviations"), Table Box(1)];
dt2 = tb << Make Combined Data Table;
tb << close window;
//Create new table for the result, each row has a unique pair of Levels
dt3 = astable( nchoosekMatrix(nitems(ColumnSplitBy), 2), << column names({"x", "y"}) );
dt3 << new column ("first", character, << set values ( ColumnSplitBy[dt3:x << get values]));
dt3 << new column ("second", character, << set values ( ColumnSplitBy[dt3:y << get values]));
dt3 << delete columns (1::2);
//Create a nested list with each pair of levels
Listdt3 = aslist( nchoosekMatrix(nitems(ColumnSplitBy), 2));
show (Listdt3);
// I tried to use associate array() to match the level and name but couldn't make it work
-Voiz
