markus
JSL: Save dashboard as interactive html
I built a dashboard from a script and want to save it as an interactive html and close it afterwards. The script runs fine, but the saving and closing doesn't.
I tried it with something similar than this, but it doesn't work.
Help is appreciated! Thanks in advance!
Markus
Open("$SAMPLE_DATA/Quality Control/Steam Turbine Historical.jmp");
app = JMP App();
app << Open File( "$SAMPLE_DASHBOARDS/Instant Dashboard.jmpappsource" );
box = app << Run;
box << save html("C:\Users\Markus\Desktop\test.htm");
close(box);
Georg
Re: JSL: Save dashboard as interactive html
I think the run application command gave a different type than you expected,
try the attached script.
tmp_path = Substitute( Right( Convert File Path( "$TEMP" ), Length( Convert File Path( "$TEMP" ) ) - 1 ), "/", "\" );
Open( "$SAMPLE_DATA/Quality Control/Steam Turbine Historical.jmp" );
app = JMP App();
box = app << Run;
Show Properties( box );
Show( box );
(box << get windows)[1] << save html( "$TEMP\test.htm" );
Georg
John_Powell_JMP
For Interactive HTML, you should use
Save Interactive HTML
instead of  'save HTML'
- John
Georg
app = JMP App();
box = app << Run;
Show( box );
Georg
markus
Hi Georg,
thanks for the advice. You are write. It is working now.
Do you have also an idea to save it as an interactive (html5) file, too?
Regards
Markus
markus
PS: The example I have taken from the community and added the saving part. In reality I build a skript which looks like this (abreviated (...) because it is very long).
HTL = JMP App( ... );
box = htl << run;
Show( box );
(box << get windows)[1] << html save( "C:\...\name.htm" );
Close( box );
I have introduced your suggestions, but it is not running. Where is the mistake?
Thanks in advance
Markus
markus
I found the mistake:
my command line said:   << html save ()
correct it should be:  << save html ()
With this it worked.
So there is still the question for the interactive html version.
Markus
John_Powell_JMP
- John
markus
Thanks to both of you John and George!
Now the script works fine!
Best Regards
Markus
