vishwasanj
JSL: Row states assignment
I am still new to the row state idea and implementation.
Can anyone tell me the syntax for selecting the first 50 rows of a data table and applying radom markers(preferably variety of markers and colors) and colors as row states ?
I really appreciate it. Thank you
Re: JSL: Row states assignment
Here is a sample script working on the Big Class sample data table.  I think it will give you an idea on how to do what you asked
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
// To color the first 20 rows, the rows outside of that
// limit need to be excluded from the coloring
dt << select where(Row()>20);
dt << hide and exclude(1);
dt << color or mark by column("sex", marker theme(hollow));
dt << color or mark by column("age");
dt << hide and exclude(0);
dt << clear select;
dt = Open( "$sample_data/big class.jmp" );
// http://www.jmp.com/support/help/Row_State_Functions.shtml
dt << setrowstates(
	J( N Rows( dt ), 1/*cols*/,
		Random Integer( 0, 15 ) * 16 // marker bits 4-7
		+ Random Integer( 0, 127 ) * 256 // color bits 8-14
Data table with row states set to random colors and markersData table with row states set to random colors and markers
dt << clear select;
dt << setrowstates(
