Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
JSL Post Extract Script always plots the dates that I made the script
I made a post-extract JSL script that plots data that I have collected for the last 30 days. I can run this daily to monitor data at work.
The issue I have is that every day I have to update the graph to the most recent 30 days. I made this script in April and it always plots March 15-April 14, even when the data collected is the most recent 30 days.
When I update the x-axis to the most recent 30 days, I can see the data I collected. I am just looking for a way around updating the date each time I use this script.
I am using
dt = currentdatatable();
Fit Group(
        Bivariate(
   and then I have all the parameters/graphs/splines listed.
Re: JSL Post Extract Script always plots the dates that I made the script
Extend your script to set the Excluded / Hidden row states before launching Bivariate.
dt << Select Where( :Date < (Today() - In Days( 30 )) << Excluded and Hidden(1);
This has solved my issue. Thank you so much!
Do your graph scripts have X-axis defined? In graph builder it would be something like this:
This could enforce scaling to your plots
Thank you, unfortunately because the x-axis is date/time it is constantly fluctuating. Mark replied above and this solution worked. I appreciate the response
