shasha_2
JSL Partition get selected rows
I am using the JMP Partition() function in my JSL script for the decision tree, I wanted to know how to get the selected rows once the user selects the segment for which rows are selected. I tried using the Get Selected Row but it's not able to understand the table. Does anyone has any idea how to code it?
Re: JSL Partition get selected rows
You can use
<< Make Row State Handler()
to trigger when new rows are selected from the Partition() platform
dt =
// Open Data Table: semiconductor capability.jmp
// → Data Table( "semiconductor capability" )
Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
f = Function( {a},
	theRows = Current Data Table() << get selected rows;
	Show( theRows );
rs = Current Data Table() << make row state handler( f );
dt << Partition(
	Y( :NPN1 ),
	X(
		:PNP1, :PNP2, :NPN2, :PNP3, :IVP1, :PNP4, :NPN3, :IVP2, :NPN4, :SIT1, :INM1, :INM2,
		:VPM1, :VPM2
Georg
if you select certain columns in the partition tree,
than you will see the selection in your table,
and can get the rows by the command "get selected rows()", see also scripting index for examples:
r = dt << Get Selected Rows();
However I do not know how you would like to control the interaction with the user selecting rows in the decision tree. A simplified example of your code would be very helpful.
Georg
You can use
dt =
f = Function( {a},
	Show( theRows );
dt << Partition(
	Y( :NPN1 ),
	X(
		:VPM1, :VPM2
shasha_2
Thanks a lot, it worked.
