swiergi11
Issues with recognizing an argument in the script
Can someone please have a look at my script and give me an idea what I'm doing wrong.
Trying to select and argument using comb box which ten is incorporated into the column name and based on that column im trying to generate control chart using the adjusted column name but it doesn't work.
New Window( "Data selection",
    <<Modal,
    Panel Box( "Select a Date Range",
        Lineup Box( N Col( 1 ),
            Text Box( "Chart ID" ),
            rr_cb = Combo Box(
                {"D0585DI", "D0585IG", "D0585L3", "D0585L2", "D0585L1"},
                <<Set Width( 5 )
    H List Box(
        Button Box( "OK",
            <<Set Function(
                Function( {self},
                    layer = rr_cb << GetText;
        Button Box( "Cancel" )
//changing the "weight"" column name to RSM_"whichever chosen argument from combo box"
:weight << Set Name( "RSM_" || layer );
//Creat control chart using RSM_"whichever choosen argument from combo box"
dt << Control Chart(
    Sample Label( :name ),
    Chart Col(
        :"RSM_" || layer,
        Levey Jennings(
            Show Zones( 1 ),
            Shade Zones( 1 ),
            Test 1( 1 ),
            Test 2( 1 ),
            Test 5( 1 ),
            Test 6( 1 ),
            Test Beyond Limits( 1 )
        Capability(
            Distribution(
                Continuous Distribution(
                    Column( :"RSM_" || layer ),
                    Quantiles( 0 ),
                    Horizontal Layout( 1 ),
                    Vertical( 0 ),
                    Outlier Box Plot( 0 ),
                    Normal Quantile Plot( 1 ),
//Fit Distribution( "All" ),
                    Process Capability(
                        Use Column Property Specs,
                        Process Capability Analysis(
                            Process Summary( 1 ),
                            Nonconformance( 0 ),
                            Within Sigma Capability( 1 ),
                            Histogram( 1, Show Within Sigma Density( 1 ) )
                    Customize Summary Statistics( Skewness( 1 ) ),
Thanks,
Tomasz
SDF1
Re: Issues with recognizing an argument in the script
Hi @swiergi11 ,
  Not sure why your existing code doesn't work. I tried something similar in the sense of wanting to have the capability analysis as part of the call within the Control Chart() call, but it doesn't "activate" it. There is another work around that you can send the command to the "object" that is the control chart and have it perform the analysis.
  Also, you'll probably want to include the LSL, USL, and Target as column properties so that it automatically performs the correct analysis. You need to assign them using the <<Set Property() command. I've included the code below.
Hope this helps!,
DS
	<<Modal,
			rr_cb = Combo Box( {"D0585DI", "D0585IG", "D0585L3", "D0585L2", "D0585L1"}, <<Set Width( 5 ) )
	H List Box(
		Button Box( "OK",
			<<Set Function(
				Function( {self},
Ycol = "RSM_" || layer;
Xcal = "RSM_" || layer;
//define your spec limits
_LSL_ = 0;
_USL_ = 100;
_Target_ = 20;
//assign the spec limits to the column of interest
Eval( Eval Expr( Column( dt, YCol ) << Set Property( "Spec Limits", {LSL( Expr( _LSL_ ) ), USL( Expr( _USL_ ) ), Target( Expr( _Target_ ) )} ) ) );
//creates the control chart object cc_obj
cc_obj = dt << Control Chart(
	KSigma( 3 ),
	Chart Col(
		As Column( Ycol ),
		Levey Jennings( Show Zones( 1 ), Shade Zones( 1 ), Test 1( 1 ), Test 2( 1 ), Test 5( 1 ), Test 6( 1 ), Test Beyond Limits( 1 ) )
//sends the Capability command to the cc_obj to update the window
cc_obj << Capability(
	As Column( Ycol ),
	Target( Expr( _Target_ ) ),
	Quantiles( 0 ),
	n
	Summary Statistics( 0 ),
	Process Capability( Use Column Property Specs ),
	Capability Analysis( LSL( Expr( _LSL_ ) ), USL( Expr( _USL_ ) ), Target( Expr( _Target_ ) ), Shewhart )
Georg
Dear @swiergi11 ,
my experience is that sometimes variable replacement in messages works and sometimes not. So what you can help here is building an expression, replace variables, and then excute the expression.
This works for the simplified example below similar to your task.
BR
Ycol = "weight";
Xcal = "height";
cc_expr = Expr(
		KSigma( 3 ),
		Chart Col(
			Expr( column(Ycol) ),
			Levey Jennings( Show Zones( 1 ), Shade Zones( 1 ), Test 1( 1 ), Test 2( 1 ), Test 5( 1 ), Test 6( 1 ), Test Beyond Limits( 1 ) ),
			Capability(
				Distribution(
						Column( Expr(Xcal ) ),
						Quantiles( 0 ),
						Capability Analysis( LSL( 90 ), USL( 110 ), Target( 105 ), Sigma( 22.2018710230259 ), Shewhart )
eval(Eval Expr( cc_expr ));
Georg
SDF1
Hi @swiergi11 ,
  I think one of the problems is how you reference the column in the Chart Col() part of the Control Chart(). The problem is that it's not evaluating the :"RSM_"||level as a column, just the :"RSM_" part and so it doesn't know what to do with the ||layer concatenation.
  As a workaround, you can evaluate the concatenation before you call the Control Chart with something like:   Ycol="RSM_"||layer; then, instead of :"RSM_"||layer as the Chart Col(), use: Cart Col( As Column(Ycol) ), and you'll be able to run the script as you expect.
  Here's the modified code below:
      <<Modal,
                    text box("Chart ID"),
                   rr_cb = Combo Box( {"D0585DI", "D0585IG","D0585L3","D0585L2", "D0585L1"}, <<Set Width( 5 ) ))),
      H List Box(
             Button Box( "OK",
                   <<Set Function(
                         Function( {self},
:weight << Set Name("RSM_"||layer);
Ycol="RSM_"||layer;
dt <<
Control Chart(
	Sample Label( :name),
		Chart Col(
			As Column(Ycol),
			Levey Jennings(
			Show Zones( 1 ),Shade Zones( 1 ),
			Test 1( 1 ),
			Test 2( 1 ),
			Test 5( 1 ),
			Test 6( 1 ),
			Capability(
			Distribution(
					 Column(:"RSM_"||layer),
					Quantiles( 0 ),
					Vertical( 0 ),
					Process Capability(
Hope this helps!,
DS
swiergi11
 Very Nice, thanks a lot.
I can generate control charts but for some reason cannot follow through with statistic, seems like second part of the control chart script has still problem.
Tried to get another argument but no luck.
	<<Modal,
			rr_cb = Combo Box(
				<<Set Width( 5 )
	H List Box(
		Button Box( "OK",
			<<Set Function(
				Function( {self},
	KSigma( 3 ),
	Chart Col(
		As Column( Ycol ),
		Levey Jennings(
			Show Zones( 1 ),
			Shade Zones( 1 ),
			Test 1( 1 ),
			Test 2( 1 ),
			Test 5( 1 ),
			Test 6( 1 ),
		Capability(
			Distribution(
					Column( As Column( Xcal ) ),
					Quantiles( 0 ),
					Vertical( 0 ),
						LSL( 0 ),
						USL( 100 ),
						Target( 20 ),
						Shewhart
I hope to see the report as below:
SDF1
Hi @swiergi11 ,
Hope this helps!,
DS
	<<Modal,
	H List Box(
		Button Box( "OK",
			<<Set Function(
				Function( {self},
_LSL_ = 0;
_USL_ = 100;
_Target_ = 20;
	KSigma( 3 ),
	Chart Col(
		As Column( Ycol ),
	As Column( Ycol ),
	Quantiles( 0 ),
	n
Georg
Dear @swiergi11 ,
BR
Ycol = "weight";
Xcal = "height";
cc_expr = Expr(
		KSigma( 3 ),
		Chart Col(
			Capability(
				Distribution(
						Quantiles( 0 ),
Georg
swiergi11
thanks a lot Georg and DS, works well now.
Both above solutions works.
