jan_solo
JSL: Open a VBS script
Hi everyone,
Is there a way to start a .vbs (visual basic script) from a jsl-script?
It is possible if I make an .exe file from the vbs and run it with Run Program(), but due to tech reasons, I prefer to run the actual .vbs.
Run Program (Executable("c:\path\VbsAsExe.exe"));
Thanks,
Jan
Re: JSL: Open a VBS script
You can use either the WScript or CScript executables to run a VBScript file using RunProgram. The only difference is that WScript will show errors in a MessageBox, whereas CScript writes the error to the console/stdout.
Here is an example using CScript.
rp = RunProgram( Executable( "CSCRIPT.EXE" ), Options( "\!"C:\runMe.vbs\!"" ), Read Function( "text" ) );
Justin
Justin
