You might also be able to use Arg() depending on your formulas. Below if very simple example:
dt = New Table("Untitled 2",
Add Rows(2),
New Column("Column 1", Numeric, "Continuous", Format("Best", 12), Set Values([1, 2])),
New Column("Column 2", Numeric, "Continuous", Format("Best", 12), Formula(:Column 1 * 2)),
New Column("Column 3", Numeric, "Continuous", Format("Best", 12), Formula(:Column 2 * 3))
cur_col_idx = 3;
Show(column(dt, cur_col_idx) << get formula);
Eval(Substitute(
Expr(
Column(dt, cur_col_idx) << Set Formula(_old_f_ + _new_mult_)
Expr(_old_f_), Column(dt, cur_col_idx) << Get Formula,
Expr(_new_mult_),
old_f = Column(dt, cur_col_idx - 1) << Get Formula;
Arg Expr(old_f, N Arg(old_f))
