SamH
JSL: How to close data tables after analysis
I am new to JSL just started 2 weeks ago.
I am trying to create analysis for many tests, few tests are stacked togehter at a time in a new data table everytime; by the time the script is done I end up with many opened data tables. I cannot close these data tables after the analysis is done. is there a way to close these open files without closing the original data file or the actual chart?
Because now, I am ending up with over 30 data files, named test, test1,...
here is a snap of my code:
NW = New Window( "TRIM_CHARTS",
dt << Stack(
            columns(
                  :TRIM_TARGET,
                  :Emulate_0000__,
                  :Emulate_0001__,
                  :Emulate_0010___,
                  :Emulate_0011__,
                  :Emulate_0100__,
                  :Emulate_0101__,
                  :Emulate_0110__,
                  :Emulate_0111__,
                  :Emulate_1000__,
                  :Emulate_1001__,
                  :Emulate_1010__,
                  :Emulate_1011__,
                  :Emulate_1100___,
                  :Emulate_1101__,
                  :Emulate_1110___,
                  :Emulate_1111__,
                  : _BEST_VALUE
            Source Label Column( "Label" ),
            Stacked Data Column( "Data" ),
            Output Table( "test" )
      Oneway(
            Y( :Data ),
            X( :Label ),
            Name( "Means/Anova" )(1),
            Means and Std Dev( 1 ),
            Mean Diamonds( 1 ),
            Mean Error Bars( 1 ),
            Std Dev Lines( 1 ),
            Connect Means( 1 ),
            X Axis Proportional( 0 ),
            Points Spread( 1 ),
            Grand Mean( 0 ),
            Dispatch(
                  "Oneway Plot",
                  FrameBox,
                  {Row Legend(
                        Temp,
                        Color( 1 ),
                        Color Theme( "Blue to Green to Red" ),
                        Marker( 0 ),
                        Marker Theme( "" ),
                        Continuous Scale( 0 ),
                        Reverse Scale( 0 ),
                        Excluded Rows( 0 )
      dt << Stack(
      columns(
                  :Ilim__TRIM_TARGET,
                  :Emulate_0000_Ilim_,
                  :Emulate_0001_Ilim_,
                  :Emulate_0010_Ilim_,
                  :_iLIM_BEST_VALUE
      Oneway(
            Y( :Data ),
            X( :Label ),
            Mean Diamonds( 1 ),
            Std Dev Lines( 1 ),
            Connect Means( 1 ),
            Points Spread( 1 ),
            Grand Mean( 0 ),
            Dispatch(
                  "Oneway Plot",
                  FrameBox,
                  {Row Legend(
                        Temp,
                        Color( 1 ),
                        Marker( 0 ),
                        Marker Theme( "" ),
                        Reverse Scale( 0 ),
                        Excluded Rows( 0 )
nw  <<     Set page setup(
    margins( 0.5, 0.5, 0.5, 0.5 ),
    scale( 0.8 ),
    portrait( 0 ),
    paper size( "A3" )
jrn = NW << Journal;
NW << save PDF( "C:\My Documents\Trim_CHARTS.pdf" );
Thanks
Sam
When you create your stacked data tables, simply make them invisible.  They will appear in the JMP Home window, but they will not have a visible window  created.
 dt << Stack(invisible,
      columns(
                  :Ilim__TRIM_TARGET,
                  :_iLIM_BEST_VALUE
SamH
Thanks Jim. it worked.
Appreciated.
SamH
this is what I end up when the final report/jrn is completed!
      columns(
                  :Ilim__TRIM_TARGET,
                  :_iLIM_BEST_VALUE
SamH
Appreciated.
It is noice to hide them, but is there any way to close all the tables without specifying their names and without closing the final output (e.g. a close all except kind of thinking).
Thanks
uday_guntupalli
Level VIII
This may not be the most efficient way to get what you want done - but it will work .
openDTs = List(); // Define an empty list to collect names of all open data tables
TableNames = List();
For( i = 1, i <= N Table(), i++,
        Insert Into( openDTs, Data Table( i ) );
        Insert Into(TableNames,Data Table(i) << get name);
// By now openDTs contains references of all tables that you have open
DontClose = {"Test1","Result"};   // Example names of tables you want to leave open
For( i = 1, i <= N Items(openDTs) , i++,
		TabName = openDTs[i] << Get Name ;
        If(Contains(DontClose,TabName),
            Continue();
            Close(openDTs[i],"No Save");
Best
Uday
Uday's code will work great, the code below just simplifies the same code
DontClose = {"Test1", "Result"};   // Example names of tables you want to leave
// Loop backwards through the list, so the table numbers do not change
For( i = N Table(), i >= 0, i--,
	If( Contains( DontClose, Data Table( i ) << get name ),
		Continue(),
		Close( Data Table( i ), "No Save" )
ivomdb
Re: JSL: How to close data tables after analysis
Hi Jim,
I am running a script that ends with this bit of script you have. In my case I am only interested in keeping 1 data table. When I run the script it does what is intended. However, when I use the JSL Debugger it stops on the If statement with the following red message: Cannot locate data table in access or evaluation of 'Data Table', Data Table/*###*/(i)
I was wondering if you know what this means?
I am just concerned that if I extend the script to do other things it will stop here regardless.
