drblove
JSL - Histograms Control where and how to place them in a Journal
I lied... one more question :)
I am trying to add a histogram with a fitted normal distribution to my Journal, and I am running into a couple of issues.  Here is the code that I am using to create the histogram:
Distribution(
	Continuous Distribution(
		Column( :Score 1 ),
		Horizontal Layout( 1 ),
		Vertical( 0 ),
		Set Bin Width( 0.2 ),
		Fit Distribution( Normal )
	Histograms Only,
		Dispatch(
			{"Score 1"},
			"1",
			ScaleBox,
			{Min( -0.323505454261101 ), Max( 1.8235054542611 ), Inc( 0.2 ),
			Minor Ticks( 0 )}
		Dispatch(
			{"Score 1"},
			"Distrib Histogram",
			FrameBox,
			{Frame Size( 382, 217 )}
		Dispatch( {"Score 1"}, "Fitted Normal", OutlineBox, {Close( 1 )} )
So when I run this it puts the result in a newly created Journal in a hierarchy of Distributions > Score 1.  Here is what I would like to do and I have questions about:
1) When I make the histogram, how can I attach this to an already created Journal by attaching it to an H List Box or is there a different trick?
2) When I do the code above, it automatically adds the Parameter Estimates from the Fitted Normal, can I suppress this output?
3) Is it possible to get "count" on the y-axis on the Histogram?
Thank you in advance, have a good holiday.
Re: JSL - Histograms Control where and how to place them in a Journal
1. The << Journal message to the Distribution platform will automatically append it to the open journal.
2. You can use the use the << Delete message to that outline before journaling the platform. See below example.
3. Use Count Axis( 1 ) option when launching the platform or send the << Count Axis( 1 ) message to the platform after launch.
Example:
// launch platform with desired options
dist = dt << Distribution(
		Column( :height ),
		Vertical( 0 ),
		Count Axis( 1 ),
// obtain reference to the report layer
distr = dist << Report;
// remove the parameter estimates from the report
distr["Parameter Estimates"] << Delete;
// append report layer to curent (open) journal
dist << Journal;
Example:
		Column( :height ),
		Vertical( 0 ),
		Count Axis( 1 ),
dist << Journal;
drblove
Hi Mark,
Thank you for this answer it is working well for me.  I have a silly follow up question.  When this goes into the Journal it is in header of Distribution >> Score 1 - Score 1 is the name of the column.  I want to change the name Score 1 for the Journal to some thing else like "Histogram of Score 1 Data", how do I do this?
Thank you!
Brad
ian_jmp
Add this line to Mark's code above (after the first occurance of 'distr'(:
distr[OutlineBox(1)] << setTitle("Histogram of Height Data");)
