DQR
DQR
Pop Up Boxes in JSL - is it possible to create submenus?
Hi - In JSL, I'd like to create a PopUp Box in which some of the items on the menu direct the user to a submenu, rather like the "Analyze | Multivariate Methods" selection from the main JMP menu leads the user to a selection of "Multivariate", "Cluster" and an assortment of others. Can this be done? And if so, how?
Many thanks
ian_jmp
Level X
Re: Pop Up Boxes in JSL - is it possible to create submenus?
If you don't mind using 'OutlineBox()' you can do this kind of thing (slightly modified from the 'Scripting Guide').
ian_jmp
Level X
DQR
DQR
I think I can live with the Outline Box once I've reduced the name of it to a single space :)  Many thanks Ian!
