キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
言語を選択 翻訳バーを非表示
JSL :: Event handling or Data binding to list boxes
Hello JMP Community,
I am in the middle of designing a GUI which allows to select an input table/ columns and an output table/ columns.  I am strunggeling with on how JSL handles mous clicks:  I want to select a table using a combo box, with a Col List Box updating following the mouse click on the combo box (how does the data binding of the Col list Box occur?).  Please have a look at the attached image for details.
Any help apprechiated!
Thanks and best,
Thorsten
1 件の受理された解決策
受理された解決策
Re: JSL :: Event handling or Data binding to list boxes
Because of the specifics on the Col List Box(), what I find the best, and maybe the only way to handle the replacement of the data table associated with the object, is to delete the object and to replace it.
QorvoPE_Select_Table = Function( {},
	table_list = {};
	For( t = 1, t <= N Table(), t++,
		Insert Into( table_list, Data Table( t ) << get name )
	QorvoPE_Select_Table_dlg = New Window( "Select Data Table For Limit Calculation. ",
		<<modal,
		<<return result,
		Panel Box( "Select Table and columns",
			select_table = Combo Box(
				table_list,
				table = select_table << get selected();
				data col clb# << delete;
				MYHLB << append(
					data col clb# = Col List Box( Data Table( select_table << get selected ), all )
			MYHLB = H List Box(
				data col clb# = Col List Box( Data Table( select_table << get selected ), all ),
QorvoPE_Select_Table;
元の投稿で解決策を見る
2件の返信2
	table_list = {};
		<<modal,
		<<return result,
				table_list,
				MYHLB << append(
			MYHLB = H List Box(
Thank you very much!
That helped a lot.
Best wishs,
--Thorsten
おすすめの記事
