drblove
JSL - Creating a table from existing table
Hi All,
So I have this issue where I would like to make a new table, out of an existing table, but want to pull values out of specific rows and add them to new columns.  My existing table looks something like this:
Subject    Value1    Value 2    Value 3
NC1         26.2        13.1         6.2
NC2         28.5        14.3         45.6
PC1         22.5        12.5         75.3
VC1         63.9        37.2         89.1
NC3         45.5        37.7         8.6
PC2         27.5        53.8         83.2
PC3         72.5        68.4         32.5
NC4         78.5        92.2         66.7
PC4         16.5        18.6         18.9
I want to create a new table of just the Value 1 where I have something like
Value     NC1    NC2    NC3    NC4
Value 1  26.2    28.5     45.5    78.5
Value 3  6.2      45.6     8.6      66.7
I am sure there is some easy way to do this, but my Googling today is not up to par...  any help would greatly be appreciated.
Re: JSL - Creating a table from existing table
Use
Tables==>Split
Tables==>Transpose
Select the values of Subject you want transposed
Use Value 1 and Value 3 as Transpose Columns
And Subject as the Label column
Then delete the unwanted columns in the new data table(
Use
Tables==>Split
Tables==>Transpose
