Elofar
JSL - Check box to select variable to then plot in graph builder
Hi everyone,
I am trying to make a script which would work this way:
1. Opens a new window showing "Select the parameters you want to plot" with a list of parameters with check box for each, and the operator would chose which ones he wants to plot by ticking them.
2. Then for the ones that are ticked, open a graph builder with the corresponding variables.
I am currently able to make the first step (new window and list with check boxes), and I know how to script to create a graph, but I miss the link between them ... I was initially thinking of calling each check box indivudally and then do a succession of "if" like "if cb1 is ticked, then do the graph, if not, then if cb2 is ticked etc ...". I tried the following script to train but it always displays "Failed" in the end no matter if I ticked the box, so it does not really check the box:
New Window( "Choose the parameters to be plotted",
cb1 = Check Box ("Parameter 1",0),
cb2 = Check Box ("Parameter 2",0)
wait(5);
If (cb1 == 1,
Graph Builder(
	Variables(
		X( :Name( "Process duration" ) ),
		Y( :Name( "Parameter 1" ) )	)	),
New Window( "Failed"));
Do you have any idea how to do that?
@martindemel
15 REPLIES 15
Elofar
Re: JSL - Check box to select variable to then plot in graph builder
I'm not sure to understand
I see the point of using the column dialog to ask the operator to select the column but still I don't know how to link that with automatic graph building after?
Example:
Names Default to Here( 1 );
dialog = Column Dialog(
	col = Col List( "X, Factor", Min Col( 1 ), Max Col( 1 ) )
If( dialog["Button"] == -1, Throw( "User cancelled" ) );
Remove From( dialog );
Eval List( dialog );
x = col[1];
dt << Graph Builder(
	Size( 534, 454 ),
	Show Control Panel( 0 ),
	Variables( X( x ), Y( :weight ) ),
	Elements( Points( X, Y, Legend( 3 ) ) )
Thomas1
Level V
Thanks Martin, for this helpful script.
kudos goes to Mark :)
/****NeverStopLearning****/
Thomas1
Level V
Sorry for that. Meanwhile I did kudos Mark as well.
SpannerHead
Simple and effective.  Nice!
Slán
SpannerHead
