See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
JMP17 ListBoxBox Fonts
ErraticAttack
It would seem that JMP17 has had a regression in ListBoxBox font's.  The example below is straight from the Scripting Index example.  It does not work.
Any ideas on a work-around?  I'm trying to set a mono-spaced font for a list box for readability purposes, and it's is now failing in the new version...
New Window( "Example", <<Show Menu( 0 ), <<Show Toolbars( 0 ), fontobj = lb = List Box( {"First Item", "Second Item", "Third Item"}, width( 200 ), max selected( 2 ), nlines( 6 ) ) );
fontobj << Set Font( "Arial Black", 12, "Italic Underline" );
JMP Pro 17.0.0 (622753) result:
JMP Pro 16.2.0 (570548) result:
Jordan
Re: JMP17 ListBoxBox Fonts
The issue appears to have been fixed in JMP 17.1.0.  Here are my results for your sample
The upgrade is available at
     File=>Preferences=>JMP Updates
Thanks for the update reminder!
Before the update.Before the update.
After the update.After the update.
