Dyan
How do replace contents in the function with a placeholder?
The First chunk of code is how ill like it to work but it doesnt.
The Second chunk of code works if i replace Variables( vars ) with it
Is there a way to get the First chunk working? Please advise if im doing something wrong here thankyou. JMP16
		//Define variables for X, X1, X2, Y, Y1, Y2, and Group X
		vars = {X(colX[i]), X(colX1[i], Position( 1 )), X(colX2[i], Position( 1 )),
				Y(colY[i]), Y(colY1[i], Position( 1 )), Y(colY2[i], Position( 1 ))
//If colGroupX[i] is not missing, add Group X statement to the variables block If( Is Missing(colGroupX[i]) != 1, vars = Insert Into( vars, Group X( colGroupX[i] ) ) );
// Graph builder code where vars is inserted into the variables
  GB = Current Data Table() << Graph Builder( Size( 1413, 999 ), Variables( vars ), // vars is placed here Elements( Points( X( 1 ), X( 2 ), X( 3 ), Y( 1 ), Y( 2 ), Legend( 11 ) ), Smoother( X( 1 ), X( 2 ), Y( 3 ), Y( 1 ), Y( 2 ), Legend( 14 ) ) ), SendToReport( Dispatch( {}, "Graph", ScaleBox, {Label Row( {Show Major Grid( 1 ), Show Minor Grid( 1 )} )} ) ) );
Variables(
X(colX[i]),
Y(colY[i]),
ErraticAttack
Re: How do replace contents in the function with a placeholder?
You need to insert expressions into the list.  With the prototype Insert Into( var, value, position ), JMP will only perform a name-lookup on var (will not try to evaluate whatever is returned from the name lookup), will perform a name lookup and evaluate value, and will perform a name lookup and evaluate position.  You want to insert an expression into the list -- thus you don't want JMP to evaluate whatever you've placed into the value position.  JMP will _always_ evaluate it however, so to keep an expression even though JMP evaluates it, wrap it in an Expr() function, like this:
        vars = {};
		If( Is Missing(colX[i]) != 1, Insert Into( vars, Expr( X(colX[i]) )));
		If(	Is Missing(colX1[i]) != 1, Insert Into( vars, Expr( X(colX1[i], Position( 1 )) )));
		If(	Is Missing(colX2[i]) != 1, Insert Into( vars, Expr( X(colX2[i], Position( 1 )) )));
		If(	Is Missing(colX3[i]) != 1, Insert Into( vars, Expr( X(colX3[i], Position( 1 )) )));
		If(	Is Missing(colX4[i]) != 1, Insert Into( vars, Expr( X(colX4[i], Position( 1 )) )));
		If( Is Missing(colY[i]) != 1, Insert Into( vars, Expr( Y(colY[i]) )));
		If(	Is Missing(colY1[i]) != 1, Insert Into( vars, Expr( Y(colY1[i], Position( 1 )) )));
		If(	Is Missing(colY2[i]) != 1, Insert Into( vars, Expr( Y(colY2[i], Position( 1 )) )));
		If(	Is Missing(colY3[i]) != 1, Insert Into( vars, Expr( Y(colY3[i], Position( 1 )) )));
		If(	Is Missing(colY4[i]) != 1, Insert Into( vars, Expr( Y(colY4[i], Position( 1 )) )));
If( Is Missing(colGroupX[i]) != 1, Insert Into( vars, Expr( Group X(colGroupX[i]) )));
Jordan
ErraticAttack
Check out Expressions -- you need to use expressions to do this.  Here is an example that should work for you:
vars = Substitute( vars, {}, Expr( Variables() ) );
Eval( Eval Expr(
	Size( 1413, 999 ),
	Expr( Name Expr( vars ) ),
	Elements(
Jordan
Dyan
Thanks for your reply, using what you have sent i tried to create a version of my own where it will add into vars if its not empty
        vars = {};
		If( Is Missing(colX[i]) != 1, Insert Into( vars, X(colX[i])));
		If(	Is Missing(colX1[i]) != 1, Insert Into( vars, X(colX1[i], Position( 1 ))));
		If(	Is Missing(colX2[i]) != 1, Insert Into( vars, X(colX2[i], Position( 1 ))));
		If(	Is Missing(colX3[i]) != 1, Insert Into( vars, X(colX3[i], Position( 1 ))));
		If(	Is Missing(colX4[i]) != 1, Insert Into( vars, X(colX4[i], Position( 1 ))));
		If( Is Missing(colY[i]) != 1, Insert Into( vars, Y(colY[i])));
		If(	Is Missing(colY1[i]) != 1, Insert Into( vars, Y(colY1[i], Position( 1 ))));
		If(	Is Missing(colY2[i]) != 1, Insert Into( vars, Y(colY2[i], Position( 1 ))));
		If(	Is Missing(colY3[i]) != 1, Insert Into( vars, Y(colY3[i], Position( 1 ))));
		If(	Is Missing(colY4[i]) != 1, Insert Into( vars, Y(colY4[i], Position( 1 ))));
If( Is Missing(colGroupX[i]) != 1, Insert Into( vars, Group X(colGroupX[i])));
When i run it, it will have an error
Name Unresolved: X in access or evaluation of 'X' , X( colX[i] ) /*###*/
But if i include into the vars statement below it works
Please advise thankyou !
ErraticAttack
        vars = {};
Jordan
vince_faller
Are you really trying to just make graph builder dynamic?  Something like this?
Names default to here( 1 );
dt = open("$SAMPLE_DATA\Big Class.jmp");
some_func = function({dt, list_x, list_y, list_group_x={}},
	{varExpr, i},
	varExpr=Expr(Variables());
	for(i=1, i<=nitems(list_x), i++,
		insert into(varExpr, EvalExpr(X(Expr(list_x[i]))));
	for(i=1, i<=nitems(list_y), i++,
		insert into(varExpr, EvalExpr(Y(Expr(list_y[i]))));
	for(i=1, i<=nitems(list_group_x), i++,
		insert into(varExpr, EvalExpr(Group X(Expr(list_group_x[i]))));
	Eval(Substitute(
		Expr(
			dt << Graph Builder(
				Size( 696, 578 ),
				DV_VARS
		Expr(DV_VARS), nameexpr(varExpr)
some_func(dt, {:weight}, {:height, :height});
some_func(dt, {:weight, :weight}, {:height}, {:age});
Vince Faller - Predictum
Dyan
Hi vince thanks for anwsering, this looks great. However, how do u change the type of plot to etc Line of fit or bar plot since the above method only works for smoother type plot.
Thanks!
