Created:
Aug 16, 2022 04:56 PM
| Last Modified: Jun 10, 2023 1:52 PM(1837 views)
I have JMP 16 and am trying to do OLE automation. I was looking at the JMPStarter example but it doesn't run. I get the "object reference not set to an instance of an object" for every button that I push. I saw from other posts that it was working in JMP 13.
Can anyone confirm that this automation example is working for JMP 16? If yes, is there anything that I have to do to get it to work? I was assuming that I should just be able to open the solution and run it from visual studio. Thanks in advance.
