UserID16644
Level V
Name Unresolved: Framebox and other properties
Hi all,
I tried creating a function but it keeps getting an error with the framebox, axisbox and outline box. I don't understand the well what is wrong with the function. Please help and explain
Name Unresolved: Framebox in access or evaluation of 'Framebox' , Framebox( 1 ) /*###*/
bivplot = Function( {x_param, y_param, int1, int2 },
	biv = Bivariate( X( Column( x_param ) ), Y( Column( y_param ) ),
	Fit Line( {Confid Curves Indiv( 0 ), Line Color( "Black" )} ),
	Fit Special( Intercept( int1 ), Slope( 1 ), {Line Color( "Purple" )} ),
	Fit Special( Intercept( int2 ), Slope( 1 ), {Line Color( "Purple" )} ));
	rbiv = biv << Report;
	rbiv[Framebox( 1 )] << {Marker Size( 3 )};
	rbiv[axisbox( 2 )] << Tick Font( style( 1 ), size( 9 ) ) << Show Major Grid( 1 ) << Show Minor Grid( 1 ) << Show Minor Ticks( 1 );
	rbiv[axisbox( 1 )] << Tick Font( style( 1 ), size( 9 ) ) << Show Major Grid( 1 ) << Show Minor Grid( 1 ) << Show Minor Ticks( 1 );
	rbiv[Framebox( 1 )] << Row Legend( Column( "Sex" ), Color( 1 ), Marker( 0 ), Color Theme( "JMP Default" ), Continuous Scale( 0 ) );
	rbiv[Outline Box( 3 )] << Close All Below;
colnamex = {"name1", "age1"};
colname = {"name2", "age2"};
int1 = {1.5, 2};
int2 ={-1.5, -2};
lapbiv = Fit Group (
			For( i = 1, i <= N Items( colname ), i++,
				bivplot( colname[i], colnamex[i], int1[i], int2[i] )
			<<{Arrange in Rows( 4 )}
			SendToReport(Dispatch({},"Fit Group", OutlineBox,{Set Title( "Correlation Plot (All)")}))
Re: Name Unresolved: Framebox and other properties
Below is a working version of your script
bivplot = Function( {x_param, y_param, int1, int2},
	biv = Bivariate(
		Column( "Sex" ),
		Color( 1 ),
		Marker( 0 ),
colnamex = {"height", "weight"};
colname = {"weight", "height"};
int1 = {1.5, 2};
int2 = {-1.5, -2};
lapbiv = Fit Group(
lapbiv << Arrange in Rows( 4 );
Report( lapbiv )[Outline Box( 1 )] << Set Title( "Correlation Plot (All)" );
6 REPLIES 6
There are a couple of issues.
  1. The Bivariate platform requires 2 numeric columns.  You are specifying a Name column which I assume is a character column.
  2. The <<[Arrange in rows(4)} and SendToReport are not syntactically correct to be passed to the Display after the platform is completed.
The following code works with the Big Class data table
int1 = {1.5, 2};
int2 ={-1.5, -2};
			//<<{Arrange in Rows( 4 )}
			//SendToReport(Dispatch({},"Fit Group", OutlineBox,{Set Title( "Correlation Plot (All)")}))
UserID16644
Level V
Hi txnelson, thank you. May I know how can I arrange the plots into 4 rows if <<[Arrange in rows(4)} and SendToReport are not syntactically correct?
	biv = Bivariate(
		Column( "Sex" ),
		Color( 1 ),
		Marker( 0 ),
int1 = {1.5, 2};
int2 = {-1.5, -2};
lapbiv = Fit Group(
UserID16644
Level V
It now works well, thank you.
But I have an additional question, why is it that when I try to add Group By (:Sex), it is prompting an error
Name Unresolved: Framebox in access or evaluation of 'Framebox' , Framebox( 1 ) /*###*/Exception in platform launch in access or evaluation of 'Fit Group'
	biv = Bivariate(
        Group By (:Sex),
		Column( "Sex" ),
		Color( 1 ),
		Marker( 0 ),
When you have a By() element in Bivariate, a separate Display Tree is created for each By variable level.  The referencing of an object below a specific level in the By variable(s), needs to be specified.
rbiv = report( biv[2] );
Below is a simple example, deleting the whole report for the second level of the By variable Sex
dt =
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
Open( "/C:/Program Files/SAS/JMPPRO/15/Samples/Data/Big Class.jmp" );
biv = bivariate( x( :height ), y( :weight ), by( :sex ) );
Show( biv );
Report( biv[2] )[Outline Box( 1 )] << delete;
UserID16644
Level V
I see. Thank you for the clear explanation
