Hi @Jeff_Perkinson using my original code, which seems similar to yours.
path = Get Default Directory();
dt = Pick File("Select .csv file with data", path, {"Excel|csv;xlsx;xls", "JMP Files|jmp;jsl;jrn", "All Files|*"}, 1, 0, "");
Open(dt,
columns(
New Column( "DateTime",
Numeric,
"Nominal",
Format( "y/m/d h:m"),
Input Format( "y/m/d h:m:s", 3 )
New Column( "NSR_ID", Character, "Nominal" ),
New Column( "TaskId", Character, "Nominal" ),
New Column( "TaskType", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "TaskCreateTime",
Numeric,
"Continuous",
Format( "y/m/d h:m:s", 26, 3 ),
New Column( "RecipeFile", Character, "Nominal" ),
New Column( "PureRecipeFile", Character, "Nominal" ),
New Column( "Product", Character, "Nominal" ),
New Column( "Layer", Character, "Nominal" ),
New Column( "LotLabel", Character, "Nominal" ),
New Column( "PureLotLabel", Character, "Nominal" ),
New Column( "Reticle1", Character, "Nominal" ),
New Column( "IllumId", Character, "Nominal" ),
New Column( "ResultFile", Character, "Nominal" ),
New Column( "ExpLogName", Character, "Nominal" ),
New Column( "AtmPres", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "AtmPresTime",
Numeric,
"Continuous",
New Column( "WCt", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "RepCt", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "AFZType", Character( 1 ), "Nominal" ),
New Column( "MeasPos/X", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "MeasPos/Y", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "MeasPos/Rot", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "MeasPos/Z", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "MeasPos/TiltX", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "MeasPos/TiltY", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "MeasMode", Character( 1 ), "Nominal" ),
New Column( "ScanVelocity", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "ScanLength", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "ScanDirection", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "ScanNum", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "MeasAveTime", Character( 1 ), "Nominal" ),
New Column( "AsocPk", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "RefMeasDate", Character, "Nominal" ),
New Column( "WTD_Z", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "IF_Roll(ZF1)", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "IF_Pitch(ZF12)", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "IF_AF-Z(Ave_ZF12)",
Numeric,
"Continuous",
New Column( "IF_AIS-Z(ZB3)", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "IF_AIS-Z(ZB3_Abbe)",
Numeric,
"Continuous",
New Column( "IF_ZF1", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "IF_ZF2", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "IF_ZF12", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "IF_ZB3", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "Roll_ZF1", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "Roll_ZF2", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "Roll_ZF12", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "Roll_ZB3", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "Pitch_ZF12", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "Pitch_ZF1ZB3", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "Pitch_ZF2ZB3", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "RetryCount", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "WaterRefInterp", Character, "Nominal" ),
New Column( "OK/NG", Character, "Nominal" ),
New Column( "G-ASOC_AFZ", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "WFMsens_Ave", Character( 1 ), "Nominal" ),
New Column( "Ave", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "TiltX", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "TiltY", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "CurveX", Character( 1 ), "Nominal" ),
New Column( "1", Character( 1 ), "Nominal" ),
New Column( "2", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "3", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "4", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "5", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "6", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "7", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "8", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "9", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "10", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "11", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "12", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "13", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "14", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "15", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "16", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "17", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "18", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "19", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "20", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "21", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "22", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "23", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "24", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "25", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "26", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "27", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "28", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "29", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "30", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "31", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "32", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "33", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "34", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "35", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "36", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "37", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "38", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "39", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "40", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "41", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "42", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "43", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "44", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "45", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "46", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "47", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "48", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "49", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "50", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "51", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "52", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "53", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "54", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "55", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "56", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "57", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "58", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "59", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "60", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "61", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "62", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "63", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "64", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "65", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "66", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "67", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "68", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "69", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "70", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "71", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "72", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "73", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "74", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "75", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "76", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "77", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "78", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "79", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "80", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "81", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "82", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "83", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "AtmPres 2", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "AtmPresTime 2",
Numeric,
"Continuous",
New Column( "AtmPresTimeDelta",
Numeric,
"Continuous",
New Column( "AtmPresEventID", Character, "Nominal" )
Import Settings(
End Of Line( CRLF, CR, LF ),
End Of Field( Comma, CSV( 1 ) ),
Strip Quotes( 0 ),
Use Apostrophe as Quotation Mark( 0 ),
Use Regional Settings( 0 ),
Scan Whole File( 1 ),
Treat empty columns as numeric( 0 ),
CompressNumericColumns( 0 ),
CompressCharacterColumns( 0 ),
CompressAllowListCheck( 0 ),
Labels( 1 ),
Column Names Start( 1 ),
Data Starts( 2 ),
Lines To Read( "All" ),
Year Rule( "20xx" )
This one works to make the DateTime "Nominal" modelling type in JMP14 but not 13.
When using your simplified script it works it creats the correct type of model.
Thank you for your help
~ Luke :)
