pichan_p
Community Trekker
JMP10 : Oneway Plot >> How to connect data points between two groups (x-axis)
Bivariate plots, I can connect data points between two groups by grouping them first then Fit Each line.
But for Oneway plots, I cant do that. Do you guys have any idea/trick?
Thanks a lot.
Jeff_Perkinson
Re: JMP10 : Oneway Plot >> How to connect data points between two groups (x-axis)
Will the Matching Column and Matching Lines options get you what you want?
-Jeff
-Jeff
Jeff_Perkinson
-Jeff
-Jeff
pichan_p
Community Trekker
Thank you so much, Jeff.
Pichan P.
