Hi Craige,
thank you for trying to help and sorry for the late reply. The script does not run.
Please find attached the script saved to the data table with the JMP 16 version (which runs properly) and the same script saved with the JMP17 version.
I think this is a bug. Are you working for JMP. If not, do you know how to I can get help directly from them?
I use this feature all the time and now I had to revert to JMP16 to be able to use it again.
Regards, Valeria
