hogi
Level XIII
Some Functions change their internal name with the language
Hi FYI.
JMP can be used with different language settings.
When a user changes the language, in general a command  keeps its "internal name"
- and the title is displayed in the other language:
e.g.
internal name: DATA FILTER
Title: Datenfilter
But there are some exceptions - like the local data filter in the Report toolbar *)
Internal name (german setting) : LOKALER DATENFILTER
Title: Lokaler Datenfilter
hogi
Level XIII
Re: Some Functions change their internal name with the language
As a consequence,
for Graph builder Toolbar (https://marketplace.jmp.com/appdetails/Graph%20Builder%20Toolbar
to get access to the first part of the icons, the display language has to be set to English.
Unfortunately, there is no command: "insert on top".
If you prefer a non-English installation of JMP and want to use on of  the shortcut icons ...
please go to the AddIn Folder and adjust the .jmpcust file:
