ClipShift
JMP reliability data
Hello JMP community,
I have some reliability data to analyse. When I use JMP Analyse >> reliability and survival >> life distribution, after I entered Y, time to Event and Censor, I selected Weibull fitting and get all statistics. How can I get the R2 for the Weibull fitting?
peng_liu
Re: JMP reliability data
When you say R2, I think you mean R-squared from least squares regression.
Life Distribution uses maximum likelihood estimation, which is the proper method compared to least squares.
So, you won't find R2.
MRB3855
Hi @ClipShift : To follow up @peng_liu  , pretty good article here comparing the two methods.
https://community.jmp.com/kvoqx44227/attachments/kvoqx44227/mastering-jmp/72/4/Genschel%20%20Meeker%...
