Thierry_S
JMP > JSL > Graph Builder > Graphic script > Multicolor Text Annotation?
Hi JMP Community,
I would like to highlight some text added to a Graph Builder plot as a Graphic Script (text (center justified, {x,y}, "GROUP1 vs GROUP2")) so that it appears as below:
GROUP1 vs GROUP2
I know how to change color between calls of the function Text, but are there control characters (similar to html) that can be used to customized the appearance within a string?
Thank you for your help.
Best,
TS
Thierry R. Sornasse
Craige_Hales
Re: JMP > JSL > Graph Builder > Graphic script > Multicolor Text Annotation?
Looking forward to an answer that handles all three colors (red,black,green) and spaces them correctly. It is easier in the text box world. You might be able to create an image and insert the image into the graph. It might be hard to get the alpha channel to make it transparent if it needs to overlap other graph elements. If it is always groups 1 and 2, and in those colors, use your favorite paint program that supports transparency to pre-build the PNG image.
Craige
