ikurtz
Statistics
We are doing an Anova test followed by a Dunnet"s post hoc test using Sigma Plot software to compare group means. The program gives the p values as <.001 or <.01 etc but NOT the exact p values.
Could we send someone the data to run on JMP and get the actual p values? We need this urgently for a paper.
Thanks
My email is [email protected]
Craige_Hales
Re: Statistics
double-click the value to get to a window that will let you set a format for the column. Change from p-value to best. You might also need more than 8 characters width.
choose a formatchoose a format
Craige
