Thierry_S
JMP > Dimension Reduction > Collapse Highly Correlated Variables (Total N = 7300)?
Hi JMP Community,
I have an extensive biomarker data set (7,300 variables) that contains multiple subsets of highly correlated variables (r > 0.95) that I want to collapse into representative variables (i.e., one aggregated variable for each group of highly correlated variables). While I can easily identify the highly correlated pairs of variables, I am struggling with identifying all the members of each group. I have experimented with Clustering, but I cannot get to a definitive answer.
Is there a method in the MultiVariate Methods that would allow me to collapse this dataset?
Of note, I cannot chare the data set because of confidentiality.
Thank you for your help.
Best,
TS
Thierry R. Sornasse
Thierry_S
Re: JMP > Dimension Reduction > Collapse Highly Correlated Variables (Total N = 7300)?
Hi JMP Community,
It seems that I tend to find part of the answer soon after posting. Step 1: Use the Variable Clustering platform under the Custer menu = completed.
Now that I have the variables clustered with Most Representative and Cluster Membership results available, what is the best way to apply the output to my table (I assume that JSL script will be involved).
Thanks for your help.
Best,
TS
Thierry R. Sornasse
Thierry_S
Hi JMP Community,
Well, I solved my question. After clustering the variables (the subset of variables with intercorrelation > 0.95), I matched the Cluster Membership and the Most Representative to the original STACKED (Tall x Narrow table). I then selected all rows with no association to a Cluster and those with a name matching the Most Representative, subsetted, and Split by Variable name. I went from 7,300 variables to 5,700 (i.e., 22% collapse).
Best,
TS
Thierry R. Sornasse
Thierry_S
Hi JMP Community,
Best,
TS
Thierry R. Sornasse
Thierry_S
Hi JMP Community,
Best,
TS
Thierry R. Sornasse
P_Bartell
Level VIII
One other thought for you besides clustering is principal components analysis. Tailor made for dimensionality reduction.
