odoyle81
JMP error: blocking ignored because cell counts were unequal
I'm trying to do a fit Y by X and I have experimental blocks, but when I try to include them, I get this error:
"Blocking ignored because cell counts unequal"
I have 20 varieties of plants, 3 biological reps of each, and 3 technical reps of each (measurements)
I want to fit the response (glucose release) to the factor (variety) and have nested blocks of bio & technical reps.
My intention is to see the variability both within technical and biological reps..
Am I doing something wrong?  I don't know why cell counts would be unequal..
homekey
Re: JMP error: blocking ignored because cell counts were unequal
Did you figure this out? I received the same error even though all my cell counts were equal.
Thanks
rhoskins
I'm having the same issue.  Please let me know if you figure anything out.
Thanks!
homekey
Hi Rhoskins,
I took a different route with my data set and ended up not needing that analysis. However, just give JMP a call or email. Once you get in contact you can email them a particular dataset and they'll help you out.
All the best!
rhoskins
Thanks!  I'll contact JMP to see if they can point me in the right direction.
