jan_solo
Check if a column has numeric data
Hi everyone,
I loop over columns in a table collected from the DB.  Some of them have no data in them (leading to empty charts).  Is there a way to check if a column has numeric values?
thx guys,
Jan
jan_solo
Re: Check if a column has numeric data
Thank you,
It seems that my version of JMP (11.1.1 x64) doesn't recognize the Anydigit function, however your answer led straigth to my answer:
ColMinValue = Col Minimum( :MyColumn );
Is Missing(ColMinValue) -> true if there is no value for ColMinValue.
Thx!!!
Jan
rw9
rw9
Anydigit(string), is 0 if doesn't contain digits, 1 if it does.
If you want to check if they are convertible to number then do:
if anyalpha(string)=0 then no upper or lower characters so assume number.
If you have special characters then compress them out.
E.g.:
data have;
  attrib my_string format=$20.;
  my_string="12345"; output;
  my_string="-12345"; output;
  my_string="ABC12345"; output;
run;
data want;
  set have;
  attrib my_num_var format=best.;
  have_any_digit=anydigit(my_string);
  have_convertible=anyalpha(compress(my_string,"-+."));
  if have_convertible=0 then my_num_var=input(my_string,best.);
run;
jan_solo
Thank you,
Thx!!!
Jan
