baba
JMP Scripting
Hello I am new to JMP Scripting and wandering if there is way to use regular expressions ?
I have huge tables and trying to stack them with JMP.
So any help on how would i ...
Data Table( "temp" ) << Stack(
columns(
  :Name( "ABC0(1)" ),
  :Name( "ABC0(2)" ),
  :Name( "ABC0(128)" )
Source Label Column( "Label" ),
Stacked Data Column( "Data" ),
output table("npt")
I have DATA = ABC0 to 127 and (1 to 128)... writing :Name takes too many lines...
Thanks,
Nevil
pmroz
Re: JMP Scripting
Here's one way to do it.  Basically you build a string and then execute it.
stack_expr = "\[Data Table( "temp" ) << Stack( columns(]\";
nc = 128;    // Set for your table
for (i = 1, i <= nc, i++,
    k = char(i);
    stack_expr = stack_expr || evalinsert("\[ :Name( "ABC0(^k^)" ) ]\");
// Add the comma between columns, except for the last one
    if (i < nc,
        stack_expr = stack_expr || ", ";
"\[Source Label Column( "Label" ),
   output table("npt"))]\";
eval(parse(stack_expr));
