osbornsarah9
How to extract column text based on character values instead of numerical values?
Hi JMP Community,
I have text in a column titled Description which looks like the following:
                                   Description Column
Row 1:     Software Issue: System Software; No Response
Row 2:     Software Issue: System Software; No Response
Row 3:     Electronics Issue: Power Supply; Response 1
Row 4:     Computer and User Interface Issue: System Software; Response 2
Okay, so I want to take the text in this column and split based on the punctuation.  So in a new column I want the text shown before the colon ":", and in another column, I want the text between the semi colon and colon ":" and ";":
So I should get:
                                             Description Column                              Column B                                  Column C
Row 1:     Software Issue: System Software; No Response          Software Issue                      System Software
I've created these new columns, and applied a formula where I tried using the character functions Left/Right (I refer to the Description Column as the text field).  However, all the character functions base length on a numerical value.  How can I use a Left/Right Character function to say
"Right(Description Column, ":")" so that I get all text before the ":"??
Thanks for your help,
-Sarah
ms
Super User (Alumni) ms
Re: How to extract column text based on character values instead of numerical values?
An alternative approach here is to use the Word() function.
Formula for Column B:
Word( 1, :Description Column, ":;" )
Formula for Column C:
Trim( Word( 2, :Description Column, ":;" ) )
pmroz
This will do what you need.  The trick is to use contains and substr to get the exact substrings that you want.
dt = New Table( "Issues",
    Add Rows( 4 ),
    New Column( "Description",
        Character,
        Nominal,
        Set Values(
            {"Software Issue: System Software; No Response",
            "Electronics Issue: Power Supply; Response 1",
            "Computer and User Interface Issue: System Software; Response 2"}
dt << new column("Column B", Character, Nominal,
                    formula(
                        colon_pos = contains(:Description, ":");
                        substr(:Description, 1, colon_pos - 1);
dt << new column("Column C", Character, Nominal,
                    formula(
                        colon_pos = contains(:Description, ": ");
                        semi_pos  = contains(:Description, "; ");
                        substr(:Description, colon_pos + 2, semi_pos - colon_pos - 2);
ms
osbornsarah9
Thank you! Both versions did exactly what I was looking for
