Steve_Kim
JMP Script : Pareto plot - combine last causes
JMP Script : Pareto plot - combine causes
Hello?
I do like to combine Last 3 causes at Pareto plot.
In this case, how can I make script?
dt = Open(
"$SAMPLE_DATA/Quality Control/Failure2.jmp"
obj = Pareto Plot( Cause( :failure ), Freq( :N ) );
Wait( 2 );
obj <<
Combine Causes(
{"miscellaneous", "silicon defect", "doping"}
I change the script as below, but it is not working.
Combine Causes( Last Causes (3) )
I appreciate your help in advance.
Re: JMP Script : Pareto plot - combine last causes
Currently, there is no scriptable method for Last Causes.  We will consider adding this in a future release.  In the meantime, you can generate the list of desired items to combine as shown below for JMP 11.
dt = Open( "$SAMPLE_DATA\Quality Control\Failure.jmp" );
/* Sort table by N */
dt << Sort( By( :N ), Order( Descending ), Replace Table );
lastCauses = 3;
combineList = {};
start = N Rows( dt ) - lastCauses + 1;
/* Build list for Last Causes */
For( i = start, i <= N Rows( dt ), i++,
Insert Into( combineList, Column( "failure" ) )
/* Use the list in Combine Causes  */
pPlot = dt << Pareto Plot(
Cause( :failure ),
Freq( :N ),
Combine Causes( combineList )
Wendy
lastCauses = 3;
combineList = {};
Cause( :failure ),
Freq( :N ),
Wendy
These options have been on our to-do list for Pareto since this item was reported. Pareto is getting a huge set of improvements in JMP 17, and I am happy to report that these JSL options will be available as well. JMP 17 will be available in mid-2022.
