kyawkag
JMP Script: How do I select rows based on variable cell value?
I'm trying to write a script to select the rows with either the SerialNo or the Data value of 1-25 (highlighted rows below).
Is there a way to select these cells with variable?
e.g
data table ()  << select where (:Item == "SerialNo[1-25] ");
Re: JMP Script: How do I select rows based on variable cell value?
You might be able to use something like this:
dt << Select Where(0 < :Num(Word(2, :Item, "[]")) < 26);
dt = New Table("Untitled",
	Add Rows(5),
	Compress File When Saved(1),
	New Column("Item",
		Character,
		"Nominal",
		Set Values({"SerialNo[1]", "SerialNo[4]", "SerialNo[26]", "Data[2]", "Data[30]"}),
		Set Display Width(75)
