Julia90
Suitable software to compute discrete choice experiment results with dual response none
I am conducting a discrete choice experiment with dual response none option.
Is there any function that can be recommended for modelling that 2-stage decision process? I used Sawtooth Lighthouse studio for first computation of results (HB analysis) but like to re-compute results in another software as well.
Thank you very much in advance.
Phil_Kay
Re: Suitable software to compute discrete choice experiment results with dual response none
I am not sure that I fully understand what you mean by "dual response none option". Also, I am not an expert on choice design and it has been some time since I have looked at this topic.
Having said that, if you want to model responses from a choice experiment where the respondents choose either one of 2 options or neither, then you can do that in JMP. The video above should be a good starting place.
Regards,
Phil
