ComplexNerd
JMP Project Global Data Filter and Column Switcher
Hello Guys,
I just started exploring jmp project. I am wondering if there is any option to add Global Data Filter and a global column switcher to a jmp project.
Currely i have created a jmp project with various reports from a datatable (similar to dashboard) but i want to know if there is a option to add a global data filter and also a global column switcher to this screen.
My idea : To create a script with column switcher . User will select reports to which it applies and when butten pressed the script will loop through all report and change column. But my doubt is how to add/pin this window (generated from script) to the jmp project. Kindly help.
Thanks in advance
0 REPLIES 0
