ComplexNerd
DataTable Prompt in application builder on module load
Hello guys,
I have applciation builder with multiple modules. one of the module only contains column list which requires selection of datatable. How to make jmp prompt to select datatable only when that module loads.
By default it prompts when the application loads
Kindly guide. Thanks in advance
0 REPLIES 0
