mquyen
JMP Pro Scripting block diagram
Is there a way we can write the expression to build multiple reliability block using a for loop?
Reliability Block Diagram(
	System Item(
		"New Diagram 1",
		Reliability Block( "Start", Position( 0, 5.72 ) ),
		Reliability Block( "End", Position( 5.82, 5.815 ) ),
		Reliability Block(
			"New Basic 1",
			Position( 2.18, 5.335 ),
			Configuration( Basic( Weibull( 1, 1 ) ) )
		Reliability Block(
			"New Basic 2",
			Position( 3.09, 5.335 ),
		Reliability Block(
			"New Basic 3",
			Position( 2.2, 6.485 ),
		Reliability Block(
			"New Basic 4",
			Position( 3.05, 6.485 ),
		Block Connections(
			{{"Start", "New Basic 1"}, {"Start", "New Basic 3"}, {"New Basic 1",
			"New Basic 2"}, {"New Basic 2", "End"}, {"New Basic 3", "New Basic 4"},
			{"New Basic 4", "End"}}
	Open System Item( "New Diagram 1" ),
	SendToEmbeddedScriptable(
		Dispatch(
			{"Distribution"},
			{1, Term Value( Time( 0.5, Lock( 0 ), Show( 1 ) ) )}
		Dispatch( {}, "", TextEditBox, {Set Wrap( 100 )} ),
		Dispatch( {}, "", Text Edit Box( 2 ), {Set Wrap( 100 )} ),
		Dispatch( {}, "", Text Edit Box( 3 ), {Set Wrap( 100 )} ),
		Dispatch( {}, "", Text Edit Box( 4 ), {Set Wrap( 100 )} ),
		Dispatch( {}, "Distribution", OutlineBox, {SetHorizontal( 1 )} )
		Dispatch(
			{"Distribution"},
Re: JMP Pro Scripting block diagram
I would approach the solution using expressions. Start with Expr( System Item() ). Create an expression for each Reliability Block ( ... ) argument and insert it. I do not know where the information for specifying each block might come from. Finally, insert the completed System Item() expression into the remaining Reliability Block Diagram( ... ) expression for evaluation.
