Learn how to build custom Python data connectors and further customize JMP’s Data Connector Framework with the Python Data Connector Demo, available now in the JMP Marketplace!
See how to use Accelerated Life Testing (ALT) to evaluate reliability. Register for June 5 webinar, 2pm US Eastern Time.
I have a quick question, does anyone know how you would approach using this Excel formula in the JMP Pro 12 formula platform to generate decile of equal distribution without using the cut point system? How do you get the INT component of the formula below in JMP? Assuming the total rows of your data table is 218086 and you want to have decile of 20,000 plus. This is what I use in Excel, but it be difficult when your data table has more than a 1 million rows than in this case Excel becomes less effective due to the 1 million rows limit.
