See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
JMP Formula
jenkins_macedo
I have a quick question, does anyone know how you would approach using this Excel formula in the JMP Pro 12 formula platform to generate decile of equal distribution without using the cut point system? How do you get the INT component of the formula below in JMP? Assuming the total rows of your data table is 218086 and you want to have decile of 20,000 plus. This is what I use in Excel, but it be difficult when your data table has more than a 1 million rows than in this case Excel becomes less effective due to the 1 million rows limit.
=INT((ROW(B2)-1)/218086*10)+1
Jenkins Macedo
ian_jmp
Level X
Re: JMP Formula
Yes, of course it's 'Floor()' not 'Round()'. Apologies.
ian_jmp
Level X
Re: JMP Formula
To round a number to the nearest integer you can use 'Round(x, 0)', where x is your number or an expression that evaluates to a number.
Re: JMP Formula
Sorry to ask this @Ian, and how exactly would that formula be?
Jenkins Macedo
Re: JMP Formula
I believe the direct translation of your formula from Excel to JMP would be:
Floor((Row()-1)/218086*10)+1;
The Floor() function returns the integer portion of the value, and the Row() function returns the row number the formula is being applied to
ian_jmp
Level X
Re: JMP Formula
Re: JMP Formula
Thanks fellows. It worked well and I was able to ranked the model scores of customers of a data table with 1.2 million in decile of 114K
Jenkins Macedo
